What will I need to buy for a SPOA
Hey Joop, how did your steering do after the spring over? Did you end up having any problems with the caster or loss of turning radius?
95 YJ, 3.5 BDS Lift, Boomerang Shackles, 32" Procomp MT
on BBJ, we made our own draglink out of blackpipe... we cut the draglink apart so we had the threads... we welded those ends inside the blackpipe.. that way, we could still use the stock ends to thread in and out
Redrooster, My steering didnt suffer at all, the only thing was that I had a hard time lengthening the drag link. And since it was too short, my steering radius was too long on one side and not enough on the other. I had an alignment shop lengthen it when they aligned my jeep. The caster ended up turning out great, I was worried when welding on the perches, but I followed the rubicon express directions and everything turned out fine.
welding on perches is no hard deal at all for a leaf spring system... just go directly over the old perches.. don't even have to remove the old ones
Joopin said:
and I recommend the drop down bracket that mounts to the frame side of the trac bar
How much is that bracket? Is it designed for a certain lift range?
Let me know what you think of it after you get it installed.
Thanks.
