1059599
I think Quadratrac equipped CJ's would be the exception to that rule. Probably not often mentioned because this axle is not a viable swap to upgrade the rear axle from an AMC20 to D44, since it has the diff offset so far to the passenger side.
I'm pretty sure all Quadratrac 4wd systems used the D44, I know it's true for SJ's and figure it also applies to CJ's.[addsig]
