What color should I paint my grill on my white tj. My auto body guy says to go with flat, but i was thinking gloss would be better. What do you guys think?
- Question for ya...Can you open your tailgate with that rack on the back of you jeep? Is it attached to a swing out tire carrier? What is the maximum load rating for the rack?
I think its rated at 200lbs, but its not a tire carrier. The two support bars that attach to the frame swing down, and then the tailgate swings open. The ratchet strap that i have on tire goes inside and around the roll bars. It helps take the weight off the tailgate as well as helps support the rack. I didnt think i would be able to fit my 33 on there with the rack, but it bearly fits.
