TwistedCU
Well the YJ is starting to show signs of age.
The auto trans started being finicky when cold, meaning it takes some waiting for it to engage into gear. It's fine once warmed up but it can't be a good sign. The transmission fluid has been changed regularly and is full and of good color/odor. I know the linkage needs adjusted, ad the needle and gear indicators don't line up as they used to, but I'm fairly certain those two things are unrelated.
To top it off, I had to park it indefinately until I have time to find the source of a gas leak. It started smelling of gasoline the other day when I took it out for a spin. Now if you walk up to it you can smell gas. I have done nothing to investigae yet as time has been tight and the weather has been poor.
I'm afraid I may go through the winter without using the YJ
Oh, well... it beats the times I didn't have a Jeep at all and thankfully it is not my DD.
