Snitty
well.. i had a nasty hole in my frame on the inside, and a bad crack on the outside...
so today i decided i was going to get a strip of metal and weld it to the bottom until i could get the means of doing the whole thing right.. the strip was to suture the underside of the frame together to absorb stress for the time being
but when i got to it, i was running out of time, so i decided to grind the crack out and weld it solid... i did so and it turned out quite nice... right now it just looks like i ground the rust off the frame.. good clean weld all the way down where the crack was
i'll get pics for you guys when i finish it up
