JamesTheScot
1994 Cherokee Country, auto trans, 2WD, 6 cylinder.
Starting has been sporadic this week. When it starts, it starts. When it won't, the starter doesn't crank at all. Maybe a click, but it's hard to tell from the cab.
I've had the battery and starter tested at automotive part stores, both tested OK. I've cleaned the battery terminals, replaced the cable clamps and generally cleaned any corrosion.
Since it first failed to start about a week ago, it has started twice normally, once with a jump (after the first non-start) and twice by touching a scredriver to the side of the solenoid.
Since then, it hasn't started for three days.
Starter relay seems an odd candidate since it has started 5 times since the first failure. I assume this relay works like a fuse where it's an all or nothing proposition.
NSS seems an odd candidate since it jumped once and twice started with a tool to the starter housing. That would be some coincidence.
Alternator seems like an odd candidate since it runs perfect (for a 15 year old Jeep) once it's started.
Any ideas?
Any ideas?
