OK, I guess that strong reply says it all.
I'm actually most worried that I'll break something (e.g. snap the head off a bolt) trying to get the driveshaft out, causing more work. I guess with some patience and PB blaster or a propane torch I should be OK.
BTW, can anyone confirm that the funny bolts (that hold on the brake caliper maybe...I'm not sure...i haven't looked closely) can be removed with a 12-point standard socket?
Thank you for the help.
