Tires
You gave a tire size not a rim/wheel size and asked about it fitting. Do you have rims? Tires? Or both? We would need to know the rim info or what vehicle it is off of to answer your question. Sent from my iPhone using Jeepz.com mobile app
The latitude and high altitude has a 17 in rim so the tire size you note(R16) will not fit on the 17 in rim. However if it is a tire and rim combo we need to know the bolt pattern info or the vehicle it came from.
