Tire Size For Stock Wrangler Sport (Question)
jusawyer
I have a stock (ie. no lift) 2003 Wrangler Sport. Would I be able to fit 32 inch BF Goodrich All Terrains or another brand of agressive looking tire? If not, is 31 inch the max I could fit?[addsig]
1054772
31" will definitely fit. I had those on my stock TJ and did fine. I dont know about the 32s[addsig]
1054779
you gonna be off-roading in it? yes= 30" tires, no=31". I hear you can find 2" coil spacers real cheap for the TJ, like less than $300. That's a cheap 2" lift for any jeep. Then you're 31" tires would look tough and you wouldn't have to worry about rubbing the flares at full stuff or on a full radius turn. :-D [addsig]
1054836
31's will fit with no problem at all. 32's will rub.... alot. If you go with 32's, do yourself a favor and spend the money for 1 3/4 spacers.[addsig]
1054852
wheel spacers take away the life of your wheel bearings. I would go with a wheel with a different backspacing.[addsig]
1054858
i think they are more like a shackle lift for coils[addsig]
