Thoughts on Watt Linkage
That's wild, and looks interesting. You'd need a pretty stout diff cover I'd bet.
I can't exactly see how the red ends are mounted, but they do look to be up and out of the way.
I am not sure. I cant think how its different then having a trac-bar with leaf springs, other then the foint in the middle.
I thinknwith some steel tubing and longer bolts, you could do a 4 point mount at the diff cover holes by making a cross shape with some flat steel. Then make the hard side mounts drop down feom the frame or body cross member and tie it all together with more steel tubing, like two cut down steering pieces feom junkyard vehicles.
The part you will really have to make is the drop down parts. That will be build as you. The diff mounts will be easy using the cover holes
