dingus
Active member
1060095
i thought it was kinda odd that a guy was selling "performance chips" on ebay for jeeps for something rediculous like a dollar or something. however, his feedback was pretty high. i read through the feedback and emailed a few people that bought the chips from him.
here's the email i sent:
hey, i noticed on ebay you picked up a "performance chip" from a guy, supposedly its a resister that you hook up on your car that makes the ECU think there is more air coming in...
i am a moderator on the discussion board over on www.jeepz.com and i have a few questions for ya:
could you go over the installation process? is it just a resister? could i just buy it at radio shack or something?
thanks,
-nate
and here's his response:
He sold me a 4700 ohm 1/8 watt resistor(could easily be purchased @ radio schack for about $.20!) This unfortunately will not work for most vehicles though. I am a liscensed journeyman electrician in Iowa and am currently persuing my masters. I own a 95 mustang GT and the PCM receives a signal from my intake air temp sensor in the constantly changing range of 0-30,000 ohms. So you can see why his 4700 resistor will not work. @4700 ohms my computer is being told that the air is approximately 150 degrees. The range is different for almost every vehicle produced and some cars(mustang before 94) don't even have this sensor! I have installed an adjustable device on my car so i can set it to whatever I want(currently @28,000 ohms) which tells my PCM the incoming air is 50 degrees. It is important to know for sure what degree = what resistance. You have to get this from your tech manual. My device replaces the stock sensor as did his. I have a larger throttle body and mass air flow sensor on my vehicle with a cold air induction and larger headers and exhaust. I would say my gains from these mods are around 50 HP and with my device I can achieve around 20 more HP which equals 70 HP! The resister theory can of course only see gains in the summer time when the air is hot coming into the motor, so you only need to use this in the hot months of summer. I don't think you would see any noticeable difference on a stock engine though..maybe 5-10 HP tops!
Aaron Olson
i just figured i'd share this so we can all be a little more informed...
-nate
thanks,
-nate
Aaron Olson
-nate
