i havent been around in a while, friends. i got a rustys 4.5" lift with quick disconnects from a friend who got hit my a cement truck at low speeds for only $200. everything aftermarket was in perfect condition. got some black rock crawler rims, blah blah.
well, i went swimming at the local rope swing the other day, just as i normally do at least once/twice a week... but this time, they had started clearing out some land by the river, and a front end loader/backhoe/something huge had went down the trail that leads to it and rutted it up pretty bad. i normally havent had a single problem getting down to the swing, but this time the ruts were so messed up and "every whicha-way".... it cocked me sideways and i went shooting into the deep end that hadnt been there before.
the jeep immediately cut off, and i feared the worst. i had some extremely good friends come help me get out, and dolly'd it back to my house. i took out the spark plugs, unplugged the ign. wire from the coil, turned her over for a second to try and spray any water out, added a tiny bit of oil to lube incase it had got water in there, cleaned off the plugs, replaced them, drained the oil, turned it for a second, flushed it with 2qts... just letting it run through. it wasnt milky or anything when it drained. replaced the air filter, filled her up with oil, and she fired up. she ran like absolute crap for a while and would cut off if i let off the gas. after a few mins she idled by herself.
after taking the first drive, the transmission will change into all gears (reverse, n etc) just fine, but when i have it in drive and im going down the road, it wont shift into 2nd gear when needed. i kept stopping and trying over and after about 20 mins of doing so it finally shifted once, and it was fine until i got to my friends. on the way home, same thing. i went probably 8 miles at 15mph trying to get it to switch. after it did, i was okay again. when i came to lights and had to stop after that, it shifted like normal when accelerating again. it idles like crap too. kinda knockey, but not to the point where im worried.
what steps should i take? is it just water in the transmission? new filter, flush, fluid? or does this sound like something a little worse?
