Tech article...
Saurian
RE: Wax stains on plastic parts
I just had to install a new alternator in my Jeep, and I took some limited pics of the process; which bolts need to come off, which bolts undo the serpent belt on a post '97 4.0, and how to access it... They are not the most detailed pics, but I could do a good description, I think, and would be willing to post an article regarding how one changes out an alternator... I'd just need to know how to go about doing so, if any mods are willing to walk me through it, like I said, I would be glad to help our little tech section :)
Sean
RE: Re: RE: 12.5" tire on 8" rim? ** Yes or No?
That would be great! The best thing to do would probably be to post your article here, and I'll just move it over to the tech forums. Try to post alot of photos (pictures worth a 1000 words you know!)
Thanks again!
I can do that... Might take a day or two to write something up, unfortunately, I don't have as many photos as I would like, but I'll work with what I've got...
Picture path is: http://usera.imagecave.com/Saurian/picture.jpg
I left it open, as I didn't know how you wanted to format as needed...
Alternator Replacement Procedure
Subject Vehicle: 2000 XJ, 4.0 I-6 (with a/c)
(underhood.jpg)
Let’s face it, we’re not all technically inclined, and if you’re anything like me, a sight like this, with your Jeep no longer working properly is pretty daunting… But trust me, this is maybe a ½ hour job if you’re really working it… I had never replaced an alternator, but after mine ate a little too much mud, it failed, and needed to be done…
Step 1: The Electric Fan
(picture coming soon)
You’ll need to remove the fan to get the serpentine belt off, or at least, it makes it a lot easier… There are two little bolts on the top of the fan… Take these off, and then uncouple the electrical connection to the fan… The fan should then pull straight up (might take a bit of wiggling)… It’s not bolted at the bottom, just wedged in there…
Step 2: The Serpentine Belt
(serpentboltsa.jpg)
With the fan out of the way, you now have access to the power steering pump assembly, which also happens to be the tension point for the serpentine belt. The first time I did this, I must have loosened about 15 different bolts before I figured it out… First, loosen the bolt circled in green… Don’t take the wheel off, just loosen it about 3-4 good turns. Then, you’ll want to twist the bold circled in red to the left… As you are turning this, the wheel you just loosened will be sliding down to the right, taking the tension off the belt… Loosen this enough to the point where you can slip the belt off the pulleys…
Step 3: The Battery Tray
(alternatorina.jpg)
As you can see from the poorly drawn green cube, the battery is right in the way for this procedure… While it could be done with it in the way, it’s a lot easier if you’ve moved it… Plus, as you’re doing electrical work on the vehicle, you’ll want to disconnect the battery anyway. Take the wires off the battery terminals, and unclamp the holder on top of the battery… Once you have pulled out the battery, you’ll see three bolts holding the tray down that it sits on… These are going to be hard to undo, word of warning now… Once these bolts are off, the tray will come right off, opening up the engine compartment as you see in the picture… There is a small sensor mounted on the tray, just be careful not to break those wires when you are pulling the tray out. I left it connected, and just hung it off the side.
Step 4: Bolts Everywhere!
(alternatorbolt1a.jpg)
(alternatorbolt2a.jpg)
Looks pretty daunting, huh? I saw all those bolts, and promptly freaked! 20 bolts holding this thing down?!? You’ve gotta be kidding me! But in reality, it’s a lot easier than this, as I found out, thankfully, before I started loosening everything in sight…
But first things first… On the back of the alternator, you’ll see a wire bolted to the back of it, and a wire harness plugging into it. These have to come off. Once you get them, there are a mere 2 bolts holding this beast on… The first picture references the top of the alternator; there is a long bolt toward the radiator, with a nut holding it on toward the back… Take the nut off, but don’t slide the bolt out yet. Now, in the second picture, you see a bolt on the bottom of the alternator… Take that one out. That’s it! Slide the top bolt out now, and the alternator can be wiggled down, then pulled out through the top. It’s in there pretty tightly, but it will come out if you rock it…
Step 5: Reassembly
(alternatorbolt1b.jpg)
The only issue you may have with the installation of the new alternator is this little sleeve circled here… If it’s too narrow; it won’t fit into the top bracket, you can tap it back with a hammer and a screwdriver (or your tapping device of choice), it will slide ever so slightly… Line it up on the top, and slip that bolt back in there… Bolt the bottom in first, then the top. Plug in the wire harness to the back of the alternator, and bolt the wire back on to it (alternator should come with new nut for doing so)
**Word of advice**… Make SURE you compare the new and old alternators… You want to check bolt positions, wire plugins on the back, and the amount of grooves in the pulley… Your Jeep’s already broken, the last thing you need is more hassle!
Rethread the serpentine belt (we’re just going in reverse now of all the steps you just did, so you can check the previous steps for reference)… Tighten up the bolt that slides the pulley until the belt is good and tight. Once it is, tighten the bolt on the wheel. This locks it in place so it doesn’t slip and loosen.
Reinstall the battery tray, and the battery… This is a nice time to install a new battery, should you be so inclined.
Slide the electric fan back down, so it presses into the slots on the bottom… Bolt the top of it back in, and plug the connector in!
(allsystemsgo.jpg)
Success! Notice how the charging system is back in it’s happy range: 13.5-14 volts… Before alternator replacement, it would not go above 12 volts (voltage of battery), and was steadily dropping until finally dying.
Congratulations! If you’re registering a charge on the system (or no battery light for those of you with no gauge), you have successfully installed your new alternator!
Related Note: If your vehicle is without battery for a while (in my case, three days), certain settings in the computer will be lost… As such, it may idle oddly, and feel like it is shifting strangely… Remember that the transmission “learns” how you drive, and adjusts settings accordingly… Give it a day or two, and it’ll be back to normal...
I’ll add more comprehensive pictures as I can get them…
Well Terry, I'll do the same. I have one article on my personal website.
If you go to my site (Located in my sig) click the Rusty's airtube button.
If you think you can use the gif do so.
You can find the article here:
http://www.geocities.com/en49ers/airtube.html
That can be my small contribution to the tech area. Not very involved, but perhaps someone will find it useful.
:wink:
