T-18 install
Schmed
I'm putting in a T-18A transmission to a 401 engine this weekend for my 83 Cj-7. I've got the transmission attached to the engine right now, with an added adapter so I can run my Dana 300 transfer case. After I attach the transfer case, what kind of problems will I run into with the crossmember? I think I'll have to cut a notch for the drain plug, and maybe drill two holes for a mount, but I think that's it. Does anyone know for sure? Also, does the transmission attach to the crossmember, or does the transfer case attach? Any other advice and tips would be appreciated. Thanks a lot
Joe
your process about drilling and cutting sounds about right but you may have to fab the mount itself, and the transmission mounts, not the tcase
Is it ok if the transmission mount is just supported by the crossmember? I have it screwed into the transmission, but I didn't screw it into the crossmember, but it's tight against the cross member. Is that ok?
