Switching from synthetic oil back to regular?
Jenns04
RE: Re: RE: LOCKERS
Is it harmful to switch from using fully synthetic oil back to using regular dino oil? I hear conflicting reports. Thanks! Jenn
RE: what next
Nope, you can even mix them.........or buy them mixed ("blend"). :wink:
RE: Re: RE: I feel the need...
if your motor has over 75K miles, I would not even consider synthetic, perhaps a blend, but straight sinthetic allows blow by in older motors.
judge09 said:
Whats the deal with the "specially formulated" oil for high mileage engines?
From what I read, it's supposed to have an "agent" to keep valve seals and other seals pliable.
RE: sway bar
You should be fine switching from synthetic back to organic oil. I don't believe in doing the opposite in an older vehicle but some would disagree. I doubt you'll hear much arguement for switching to organic oil though.
