1062186
Here's a good one for y'all. My TJ is developing this hesitation problem that my old YJ used to have as well. The circumstances surrounding them are quite similar so I'd like to see what everyone thinks. Ok, so it does this thing were if I drive it for a bit, then park it and let it rest for anywhere from 10 minutes to an hour, when I start cruising down the road again, it starts to hesitate, and sputter, almost like it's not getting enough gas or something. Almost like a vapor lock. So I have to push the clutch in, let it settle, and then it runs fine. This seems to have started to happen with both my rides around the same time that my catalytic converter started breaking up inside. This led me to believe that the broken pieces of cat were clogging the exhaust and choking the engine. However, when I put a new cat on my YJ, the problem didn't go away. I also replaced the TPS and finally the O2 sensor. Nothing really seemed to fix the problem immediately. It did go away on my YJ about a month or so after I replaced the O2 sensor. But I was also living in NC at the time, and I didn't really ever run the engine that hard since it's all flat down there so whether or not I really fixed it, or it healed itself, I'm not sure. Anyway, now my TJ is doing the same thing. The cat and most likely the O2 sensor are getting replaced next week, so we'll see if that fixes anything. I'd like to go live in NC again and see if that fixes the problem, but that just doesn't seem practical. Has anyone ever encountered this or can anyone offer a suggestion as to what might be causing the problem?[addsig]
