steering shimmy
nelson
Re: RE: Name That Jeep
Need some help,
I have 2002 wrangler x with a 4 inpro comp lift and 33s.
i experience real bad sttering shimmy at highway speeds. it goes away when i let off the gas and slow down. it is annoying. i have had it alignewd, rotated and balanced.
i have a pro comp steering stabilizer. Do i need to replace it or is it something else??????????????
RE: American Beheading in Iraq
is that a long or short arm lift
Welcome, nelson. How long have you had the jeep? How long the 33's been on there?
I'd check the front track bar very closely, watch both ends as somebody turns the steering wheel to full lock. Have them bounce the steering wheel back and forth against full lock and you may see a little movement in the front track bar.
Re: RE: Re: RE: Name That Jeep
Welcome to Jeepz.com
Did this happen immediately after the lift was put on or was it okay for a while and then started?
