A good sand-blast on the frame will help. It will reveal any soft spots, and give you something good to etch, and paint. I would suggest some Por-15. It's good stuff, and won't fail you. You might consider boxing in the frame while you're at it. >> Depends on if your planning on abusing it when it is complete (you've got it apart, why not?) . As far as the body goes, depending on the condition, if it is in good shape, clean it up and go. If in poor shape, have someone media blast it with walnut shells. This will remove all the rust without "digging in" to the good steel. Other than that, take your time, don't half-arse it, and have fun. Rember: It's a hobby, not a job. Later, Brad
