spark plugs
kreatos909
hey guys got a 95 cherokee h.o 4.0 and i got the champion copper plugs from autozone and 3 went in but the other 3 would not go in. i previously had the bosch champion 2 double tip ones and they went back in just fine but the champion ones wouldnt. need help dont know why they wouldnt. old ones went back in without a problem
puzzling..Did you double check to make sure all the plugs were the same? Not so much on the box but on the plug themselves
That is odd. 2nd on checking the 1st 3 plugs with ones that no go. Also check old plugs to see if cross threaded?? Sounds like head maybe cross threaded. Spark plug chasers are pretty cheap, then put anti-sieze on new plugs.
As for plug brand. Champion coppers are good. 03+ Jeep use NGK. The rest were champrion copper core. Most Platinum or premiums are overkill and waste of $$.
