MrChubbyHubby
Hey Guys. I need help. I have a 95YJ w/ 2.5L. About 50 miles ago I started hearing an ever so slight "chatter". It has gotten so loud that I am afraid to drive it and would call it a "rapping" in gears 2 thru 5 at this point (may be too suble in 1st gear). It starts at about 1500rpm and does not stop. The noise only stops when I push in the clutch and coast. When I rev in Nuetral or with clutch in.... no noise. Which makes me think its a drivetrain issue. This is when I am in 2WD.
Transmission was rebuilt 2K miles ago, and the clutch was put in at the same time. I checked the rear shaft and the U-joints seems to look okay. There is a small bit of play (when I try to rotate the rear shaft) but everything seems to be moving together (shaft, into the rear diff, and into the T-case)
One thing I did notice while checking things out last night is on the front shaft. when I push up on it, there seems to be about 3/8 to a 1/2 inch of play. Most movement is seen where the larger part of the shaft gets a bit smaller and then goes to the front U-joint. Could this be related to a budget lift job by previous owner??
I am new at this .... so please please help my sick baby. I am begining to think I was taken when I bought this mess.
Thanks
Thanks
