well the fight continues. in my attempt to defeat the DW on my '97 3" XJ i have replaced the following:
- new OME steering stablizer
- 4 new OME nitrocharger heavy duty shocks
- a new tracbar
- BDS lca's (for 3" lift) and BDS uca's (adjustable)
- new steering box
- all new bushings
- new upper and lower ball joints
i also put on a brand new set of tires and different rims (borrowed from the stealership) to see if that corrected the problem... and although it seemed to help, it didn't offer a complete fix by any means. a lot of the work listed above has helped, but only to a degree. i think i have a lot of small issues contributing to the overall wobble.
the biggest difference seemed to come with the new control arms. without them, the thing would go crazy at the slightest bump. now i have to hit something pretty good to get it to wobble (well, actually i just discovered the other day that i can sometimes induce the wobble just by jerking my steering wheel back and forth a few times... that sucks).
back to the control arms though... i'm guessing that means i'm dealing mostly with a caster angle problem. i still have a lot of adjustment in my uca's and plan to keep messing with them. i've read the stock XJ caster angles are 5-7 degrees. is that correct? i guess the guys at the alignment shop should be able to tell me what my caster is and i can adjust the uppers to bring it back to spec and get a good alignment.
i know i've posted basically the same message quite a few times over the past few months... but i'm getting pretty desperate. oh and here's the weird thing... it worked perfectly fine for well over a year after i put the lift on (with stock arms/stock everything). go figure...
- a new tracbar
- new steering box
- all new bushings
