Snorkles...
WarthogExplorer
Two questions about snorkles for TJs:
1. Can someone post, or e-mail me pics of what the snorkle looks like under the hood? I've seen lots of pics of the outside, but none inside.
2. Can you use a standard K&N filtercharger with a snorkle? Not the FIPK, just a normal drop-in K&N, rectangluar filter.
Thanks for any help!
Don't have any pics of the inside of a TJ but I have some of my YJ setup if you want. As for using a straight drop in K&N, yes you can use them. If the setup is similiar to that of a YJ, the ARB kit comes with a plug to cover the stock intake location on your airbox so you have to cut a hole in the side of it and mount the supplied adapter that will allow you to clamp the flex hose to it which will run to your snorkel.
