JeepGirl247
My lawn tractor has been in storage all winter and I decided to start it up yesterday for the first time in about 3 months. The one year old refurbished high power battery was completely disconnected while it was in storage so it wouldn't drain. It was in about 45F degrees in sunshine when I tried to start it. I turned the key to start it and it just kept "chugging" and wouldn't actually turn-over 100%. I stopped after about 15 "chugs" and then tried again. The second time it had slightly more power but still wouldn't turn over completely to start it. During this second attempt, I noticed a small line of smoke coming up from the negative battery terminal area. I immediately turned the ignition off, took the key out, and then waited about 10 more seconds and the smoke had gone away. I then disconnected both battery cables and haven't been back to the tractor because I don't know what is going on. Why would it be smoking? Any insight into how I can get my tractor started would be great. Thank you.
[SIZE=-1][SIZE=-2][/SIZE][/SIZE]
