Ever feel really good about your rig? Get set up for a hard trail and you know everything is a go?
Firstly, we decided not to go to Slaughterhouse Gulch. There was a group meeting at Johnson's Village for a run on Chinaman's Gulch. We decided to join them.
That's what I thought when we headed out for a trial at Chinaman's Gulch near Buena Vista, Colorado. Could have done it, too! except that...
We had made it through the preliminaries. The steeps with their rocky lines. The extreme downhills that can flex your suspension. To the loop and beyond. Then Tom drove the "Rock Garden" obstacle. Somehow, as the Mighty YJ traversed the obstacle, he buried the driver side front tire in a hole. He was just getting it out when the back tire tried to climb a rock step. Way too much pressure was applied to the rear axle and the rear driveshaft broke. When that happened, the welds on the rear spring perches broke. We stuffed a rag in to the opening and duct taped it closed. Then we pointed the differential up to the bottom of the Jeep.
Now, we had a fairly serious break in the middle of a deep trail. The front axle was engaged and working so we were technically able to drive it out. We'd have to solve a couple of minor problems first. When the drive shaft broke, it had to be removed. The easiest way to do that was to pull the slip yoke from the transfer case. That left a large hole that the transmission fluid would very rapidly leak out through. We came up with a quick and somewhat ingenious solution.
Someone was standing by with a water bottle. We had him drink it to give us the bottle. We cut off the top of the bottle. It fit into the opening. We got a tight fit and duct taped it into place.
We told the group that we would head back out. As is the credo of the trail, people were volunteering to go with us. It was a large group. We didn't want anyone to miss the fun, so Tom and I elected to head out by ourselves. The trail is well travelled and if we couldn't make a spot, we could wait until the group finished the upper loop. We were also on the CB and FRS radios.
The group headed onward toward the "Whale's Tail" and we headed out. We got out to the beginning of the upper loop without a problem. From there it was a steep hill down and then a few heading up. Down was not problem. Up? Even locked, we were pulling the Mighty YJ and it couldn't get the traction to climb the hill. We had to winch. We winched a total of 7 times. It was slow going, but we were finally off the trail.
We checked the transfer case and the quick fix was working! We contacted the group that we were heading back to Denver. They told us that they would keep the channel open and look for us on the way back. We thanked them and headed out.
Being in 4 wheel drive on the front axle, it was wise to drive no faster than 40 mph. Saturday late afternoon was a good time to have that limitation. We inconvenienced few on the 5 hour drive back. We stopped several times to check the transfer case fix. It held all the way back to Denver. It is still holding as the Jeep sits in front of the house.
Overall, a good if somewhat stressful weekend. How much will this event cost? About $250 to switch over to a slip yoke eliminator and $300 for a new drive shaft. Oh Well...
