uglybrowncj
I'm having a problem with the braking on my '93 YJ. It's a 4 cyl 5 spd. 4 in. SUA lift with 33s. The axles are stock, as is the rest of the drive train. When decelerating, there is a pretty harsh vibration in the drive train. It doesn't occur when the brakes are pressed lightly, but when they are pressed medium to hard. The entire drive train shakes and you can feel it in the gear shifter. I already tightened all of the suspension hardware including the leaf spring plates. They were loose, but this did not solve the problem.
