Should I pull the engine or drop the transmission????
Jeepster05
I have to replace my slave cylinder next week and I am looking for the easiest and fastest way to do so. Boy do I appreciate jeep putting that darn thing internal or I'd be on the road right now. anyone have any recomendations??[addsig]
1074848
I went with the transmission and transfer case drop. Less to un hook and rehook in my humble oppenion! But it is just that my oppenion. tug[addsig]
1074862
yeah... you will be much better off dropping the transmission... or even using a transmission jack, and just sliding it back... that way, you don't have to muscle it back around... just bring it down, then back... then when you are done... slid her forward, up, forward... done...
its not quite that easy... but not TOO bad[addsig]
1074934
Drop the transmission/transfer case. Let us know if you need anything else. It's not too hard, just time consuming.[addsig]
1075148
I just did mine drop the transmission ...much easier..
and alot faster with a big floor jack... :-D [addsig]
1075157
I'm having a little trouble getting the front driveshaft off. I got the little u shaped bolts that hold the u joints in off but I couldn't figure out how to work the shaft out of t he tcase. and boy did i have a hell of a time getting the bolts out of the skid plate, took me a while just to break the bolts (and a cut up tow). I ordered the clutch that higgins posted and it will get here tomorrow (wednesday). Awesome deal thanks for finding that.[addsig]
1075161
You are thanking the wrong man even though I
would like to claim it Snitty is the one that found that
awsome deal....... :-D [addsig]
1075170
Once the bolts and straps are out, you may need to pry the u-joint out of the yoke. They get stuck in there and take some persuading to get out.
Post any headaches you have along the way, and we'll help you out, hopefully.[addsig]
1075258
haha.. glad to help guys... i found that when i was repacing my transmission... unfortunately, i didn't have the money to replace the clutch with it... so when that goes... i'll be in there again[addsig]
