Getting ready to put a black diamond 3" suspension lift on my '97 TJ...I need some advice on whether to purchase 15x8s or 15x10 wheels. The tires will be 32X11.50 BFG AT's.[addsig]
my advise would be to go with 15 x 8, you will have more grip and a better shape when you air down, also a little less likely to pop a tyre off the bead espeacily if you use a inner tube
bernie[addsig]
But more important is the correct back spacing on the wheels for propper fit and performance. We ran 4 1/8 inch back spacing on our 1997 TJ to eliminate tire/frame rubbing and 15 x 8 to keep the tires from not sticking out to much and allowing the tires to tuck under the flairs when off-roading.
Note: Those tires are fine, but No inner tubes. [addsig]
no doup 15x8 its all you need for those side of tires,plus if you ain't planning going bigger then 33x12.50 than thats all you need,oh another thing 15x10 look too wide i personaly don't like it [addsig]
I put a used set of 33-12.50-15 on my Jeep this weekend for fitment to see how much lift I need, and I used my 8in. wheels. I will have to say when I get the new 33s I will use these wheels, they look pretty good. [addsig]
alright, so 15x8 it is...Anyone know where I can find some black rockcrawer wheels for pretty cheap? I dont need beadlocks....also, anyone had experience with the black diamond lifts?[addsig]
