She wont start help!
jeepdude832
I went wheelin yesterday no problems drove all the way home. I stopped at a gas station to reconect my disconects no problem drove about an hour home no problem. This morning when I go to start she wont. It turns over fine but it wont start. I went through some puddles but nothing deeper than my steps. My engine comparment is all muddy but I have done that tons of times with no problem. I even hose it off sometimes before but this time she wont start. I checked my distribtor but its dry I am replacing it right now because its worn any way. I sprayed wd-40 on every thing I could think of in case there is moisture. I need help I dont know what else to do. 99 tj 4.0 Thanks
2wd to 4wd???
check ur PCM on the firewall behind the battery, make sure all the connections are dry, then make sure u dont have water in the gas
need tJ suspension help
Thats exactly what it was I checked that right after I posted this . moisture had gotten into the conection between my jet chip and the fire wall. It works great now
good u might want to put some dielectric grease in between that connector, it will keep moisture out and water will stay out too.
