What is the largest shackle lift you can fit on a YJ before u have to get a pitman are and drop the shifter and brakes.If possible i would just like to be able to bolt the shakles up and go and not have to mess with nething else.
The biggest shackle lift I've ever seen is an inch and a half. But I think if you do any type of shackle or suspension lift, if you go over 2.5 inches, you need to start messing around with the pitman arm and transfer case, etc. [addsig]
