I did some research, and it looks like you need to ground the Purple/yellow stripe wire that's in the driver kick area. Cut the wire and ground the engine side, cap the door side. The wire is easily locatable in the bundle which runs to the door. The way to determine if the security system is disabled is when you lock the doors with the remote, the security system light at the dash will not illuminate. If it illuminates it is still working.
Note that this won't work if your security system has been enabled and the ignition has already been killed.
I don't have any first hand knowledge with this, so take it with a grain of salt.
