69jeepcj said:OH BOY! I put mine in about 2months ago and I never did change the oil... what gona happen?????? should I change it ASAP
I wouldn't recommend this, great way to spin a bearing and ruin your engine.Something crazy I've seen is using deisel fuel to clean out gunk from your block
Bounty__Hunter said:I wouldn't recommend this, great way to spin a bearing and ruin your engine.
I like how you go on to NOT recommend it for any engines LOL.
Something crazy I've seen is using deisel fuel to clean out gunk from your block. It's a little more involved than seafoam but you wouldnt believe the amount of crap it breaks up... If your willing.. drain your oil and remove your sparkplugs and disconnect th coil. Then replace the oil drain plug poor about 2-3 quarts of diesel fuel in your oil fill and crank the engine with the spark plugs out or if you can pump the oil pump.. don't know if you can on jeeps but I know on many v8s you can attatch a drill to the oil pump down the distributor shaft... Like I said more in involved but after its been pumped through the engine and you drain it EVERYTHING comes out. Then put some cheap motor oil back in the motor and pump it through the engine to get any remaining deisel fuel out of the block. Put everything back together and change the cheap oil like you would normally and your good to go
It's quite a bit more work but it deep cleans the engine. I wouldn't recomend it on a real high mileage engine with leaky seals tho... It might break up too much and make leaks worse. Might not even recommend it on a normal DD engine. The only time I've seen and helped with this proccess is to clean out an old motor that had been sitting for a few decades. Ran real perty after tho
frhrwa said:I've taken out 2 quarts of oil, replaced it with diesel, start my car and let it idle for about 5 minutes, then drained it good, left the drain plug out for a few hrs.. put cheap oil in and a new filter, ran it for a day or so, then changed my oil back to good oil .... cleaned it out completely.. done that many times over the years.. never had any problems doing it.. diesel is an excellent sludge cleaner, just don't go driving around with it in there.. let it idle, get warm, and drain it.. 5 or even 10 minutes will dissolve the sludge, no rev with keep it from slinging into places you wouldn't want it.. but just pumping it through cleans it great..
