85zebracherokee
Ok so as I understand it if you use a 6" lift kit you need a S.Y.E. (slip yolk eliminator) when you use this it says you need a longer drive shaft, are there any drive shafts off of another vehicle that will fit? Or does it have to be custom made? Also with a 6" lift do you need a different front drive shaft?
Thanks Jon
Thanks Jon
