Ring and Pinion Change
geronimo_e
Hi, i was wondering, do i have to change the R&P on the 2 axels when i do a swap or can i just change the rear one, from a 3.31 to a 4.11?? Thanks for the help... :-? [addsig]
1068331
Unless you never will put it in 4 wheel drive then you ahve to have the ratios match.[addsig]
1068332
yeah... both axles... unless you only drive in 2wd... or if you have different size tires to make up for it... best do both[addsig]
1068352
ok, and do they have to be 4.11 in the front and 4.11 in the back or is there a diference in ratio's. A friend told me that the front axel spins faster than the rear one, becouse of the transfer case, is that true... Thanks for the information, it's been very usefull. :) [addsig]
1068360
Nope, the front doesn't spin faster due to the tansfer case. If you have 4.11s in the rear you MUST have 4.11s in the front if you want to put it in 4WD.
TARSI[addsig]
1068362
If the gearing does not match front and back the wheels front and back will pull at different speeds. Thuss your rear end will try to pass your front end or your front end will go so much faster than your rear end you will wind up in a Jeep Limo! hehehehe tug :-D :lol: ;-) :lol: :-D [addsig]
