Rhino liner questions
Jeepster05
What do you do with the wires that run underneath the carpet when you have Rhino liner or Line x sprayed on????
1052130
Line-X is just so bad ass... it doesn't matter what you do with the wires... You'll have one badass floor... sorry for not being much help[addsig]
1052140
Once the liner is done it becomes a one-piece solid coating. We actually installed marine (brass) screw type drains in the floor wells before spraying for future ease of clean up. If the wires have a need to be replaced or serviced, you might want to re-run them around the edge of the tub first. Other wise we sprayed over ours (No problems yet). The Rhino/Line-X's (Spray style coatings) are a bit pricey, and the Hurculiner's (Brush on style coatings) do give a little protection, but their thin and you get what you pay for (Just an opinion). There are some new coatings at car shows that might also be worth looking into (Seems prices are coming down). I have found Rhino (In direct sunlight) to fade after a while and show cuts in some cases, where Line-X is harder and items tend to slide around more and the texture is harder on the knees.
Anyway you do it, it is a nice upgrade.
