JeepMonkey
So When I replaced my manifold w/ a header a few weeks ago I couldn't get two of the bolts back on and tight. I left them off and as you can probably imagine there is an exhaust leak. Not too bad considering, but bad enough that it's throwin the "check engine" light. Anyway, can I get some of the replacement allen head style header bolts? I think I can get them tight since I could actually get an allen wrench socket down there whereas I couldn't get a standard socket to fit. I've used these bolts before on GM motors with headers and they're so much easier to tighten up, but I'm not sure if they're available for the 4.0 Jeep motor. I haven't called Kragen yet, but I figured maybe somebody here had some previous experience. Thanks in advance~!
