related electrical issues?
Nomad
I have a 94 GC laredo with a few electrical issues. The ABS light is on, the auto headlights are on day and night, door/ seat belt chimes stays on intermittantly, and the radio seems to have a ground issue(plays louder if you push on the face plate). Are any of these items related? or is it just wishful thinking?
Thanks in advance for your help.
Nomad
The ABS lamp on could be an abs wheel sensor going bad. The auto headlight could be a photosensor going bad or obstructed(covered) by a dash pad. Seat belt chime could be either one of the door jamb switches intermittently sensing an open door when its not or the seat belt buckle switch is intermittently shorting to ground. The Radio Volume is the Weird one. possibly a Potentiometer(Volume Control) going bad or just dirty. or it could just be as simple as a loose connection on the back of the radio. these are just possible causes according to how you described the issues.
