Ramsey rep 8000e winch? Why is this so cheap?
Better weigh your XJ? And when pulling, add quite a bit of weight for whatever it is that has your jeep stuck, be it mud, rocks, sand, whatever. Mud can quickly double the weight the winch is pulling, if you're stuck right :lol:
Hey I just found you a deal on a WARN > Winch M8000
499.99 with Free Shipping
Rated Line Pull: 8000 lbs. (3629 kgs.)
Motor: 4.8 hp/3.6 kw, Series Wound
Control: Remote switch, 12' (3.7m) lead
Gear Train: 3-Stage Planetary
Gear Ratio: 216:1
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum Diameter/Length: 2.5"/9.0" (6.4cm/23cm)
Weight: 74 lbs. (34 kgs.)
Wire Rope: 80' 5/16" diameter (30m, 8mm diameter)
Recommended Battery: 650 CCA minimum for winching
Finish: Argent Powder Coat
Warranty: Limited Lifetime
