Re: RE: Re: RE: Re: RE: Going newer... Got Questions.
Hi-Ya, MrChubbyHubby,
What follows might be too late to be of use to you; nevertheless, for what it might be worth:
I use foam tape designed for application between a pickup truck and a cargo bed cap. The tape is 1.5 inches wide and 1/8 inch thick. The tape is adhesive-coated on one side, with a paper backing that must be peeled off to expose the adhesive.
My CJ-7 hardtop is suspended from garage roof rafters when not mounted on the Jeep. Before lowering the hardtop down onto the Jeep for the winter, I apply the tape (sticky side up) to the underside of the hardtop mounting flange, then poke holes through the tape for the eight hardtop mounting bolts.
Works for me, but the hardtop is inherently noisy. It seems to act as a sounding board - sorta like living inside of a guitar. The tape will help to suppress the road noise only to a limited extent.
I bought the tape at a Sears hardware heaven store, but the tape should also be available at a pickup truck cap-camper store.
One roll of tape, about $6.00, is long enough to weather-strip a CJ hardtop several times.
Regards,
Gadget
