baldjohnny
YJ starts up and idles fine, at least to my "untrained" ears. It's had the "tap" sound that I have heard others describe, that mostly goes away as it warms up. What it's doing now:
1. 1st gear acceleration- great.
2. 2nd gear acceleration- good, but I can feel the beginnings of a miss. Around 2000-2200 starts the miss.
3. 3rd gear & 4th gear- Seems to be a miss that is more exaggerated now, but I can "minimize" the miss by keeping on the gas.
It threw some codes I caught by reading the check engine light: 1-2, 3-3, and 5-5. I checked the fault codes and the 1st one makes sense (disconected the negative battery cable), but the other two... don't have A/C for # 2 and the PCM reference is puzzling on # 3.
Worse case scenario I'll run it down to the dealer and have them hook it up, but it baffles me why it will accelerate just fine in first and most of 2nd, then shudder in 3rd and 4th. I put in the clutch, it goes away as I am rolling down the road. Replaced coil, cap and rotor, wires are fairly new.
Does this ring a bell with anyone? Like I said, it may be dealer-bound because I'm getting tired of playing with it and really don't want to take what may be a minor problem and turn it into a costly "what the hell have I done now" problem, but I sure like the idea of trying to figure it out myself first! And hell, if I can't ask you all, who can I ask?
Thanks for any suggestions.
John
John
