derreckjett
I have a 94 grand cherokee with power windows that has one window that will go up.  I replaced the motor thinking that would be the obvious fix only to find that the problem persists.  If I swap the leads to the motor and press the switch to roll the window down it will go up but that is the only way.  Any suggestions on what the issue might be?  Thanks!
