It only takes about 30 minutes, including installing the switch.
I mounted mine under the dash. Cut two vertical lines with a hacksaw in the small lip that curls back from the bottom of the dash. I then bent that piece flat with the bottom of the dash to have a larger flat area to mount the switch. Drill a hole and the threaded area of the switch goes right in, securing with one big nut.
It's a great mod if your familiar with the vacuum disconnect on the front axle and now how to keep it in good working order. I carry a spare vacuum disconnect as well, so it's only about a 5-minute swap out.
