popping noise
jeepgirl33
I'm having an issue with popping noise from the front driver side when I make a turn. Can anyone help shine a light on my issue.
Check the u-joints on the axle shaft, wheel bearings , sway bar links and brake calipers. A loose lug nuts can also cause that symptom.
