If you're able to talk to the previous owner, find out from them firsthand.  Not all aftermarket poly tanks are capable of being converted to 20 gallon.  The capacity of the tank should be stamped into the exterior (usually on the top).  If you decide to drop your tank, be wise and have as little fuel in there as possible.  How many gallons of fuel do you max out at now?
