Although I cannot truly answer your question , a seven inch lift is extreme and will , at the minimum , require a t-case drop so that the drive line angles will be consistent . I'm sure you know that trans/t-case centerline must agree with pinion centerline in terms of being level .
That will most certainly need for the driveshafts to be the correct length to achieve that .
The only question I have is , does the engine need to be dropped as well to help keep the centerline level with the body ? I don't have the specifications which are something along the lines of a formula to keep all parts consistent . I would think that the engine centerline , trans , t-case must first be level with the body but dropped below the original factory installed position so that the lower pinion centerline is consistent with the powertrain/drivetrain centerline . Most important is these centerline have to be the same or close to same to avoid u-joint stress and failure. This seems to be asking a lot , but in order for all to work together and play nice with each other , they must agree. Someone must have the "formula " to tell powertrain/drivetrain drop with pinion drop to achieve equal and consistent centerlines to be level with each other to achieve this seven inch drop. You know you just can't install hi-lift springs and increase u-joint angle and expect it to work,. U-joints can only swivel up,to a certain angle before they'll fail.
hence , the reason for powertrain/drivetrain drop. This is to keep the u-joint angles correct.
I know I did not answer the question , but I just wanted to give you something to think about , not knowing if you had a grasp on the effects of lift versus angle. When u-joints are out of phase with each other , on both front and rear shafts too , failure is inevitable. We don't want you to begin ordering parts and finding that they won't work together. I believe you know this or have an idea at least or wouldn't have posed the question. Yes , try to research as well but I hope soon you will hear from a member who has successfully performed a lift of this much.
