Penziol Syncromesh
L33TJ33P
Well, the Syncromesh is paid for, the TJ is up on Ramps I am under the Transmission and guess what. I can't find the Drain and the Fill plugs. :-( I have been warned through the Stealership and Jeepz.com to make DANG SURE I know which is which, as on bolt seams to drop little pieces and parts. All I am finding is 3 bolts that seam to need a GIANT Alan Wrench. Does the Skid plate cover what I need to be getting to??[addsig]
1075790
the drain plug should be NOT covered by the skid plate[addsig]
1075798
The drain plug is out about an inch in front of the skid and it should be an allen wrench. The fill plug is on the drivers side and about half way up the side in the same line as the drain.
This for for 2000 and newer with the 3500
