I have an o3 Tj 4.0 AT 48,000 mi. The other day I couldn't start the jeep, I did a thorough inspection (battery, starter, solenoids, fuses and wiring) I found that a small piece of pot metal had broken within the ignition switch. I replaced the broken piece and now the Jeep starts - BUT for only 2-3 seconds. First thing that comes to mind is a SKIM module problem...except there isn't a SKIM module in my Jeep. I verified this through the local key shop and there is no SKIS/SKIM unit on my column. So it seems that my PCM is thinking that I have a SKIM and shutting the engine down? I have been researching this problem and I have not yet found any forums where someone with no SKIM in their vehicle has experienced a SKIM related problem (I also ran an OBDII test and recieved a P1686 code - "no bus - SKIM module") I have done the battery discharge/lights on/lights off/key off - to flash the PCM but still having the same problem. I am fearfull that I will have to purchase a new/refurbished PCM and then have to tow my Jeep to a dealership so they can reprogram it. I have been researching forums to see if this has happened to anyone else and if anyone is aware if the dealership can fix the PCM problem without me having to purchase a new PCM ... please help ... I detest dealerships and I enjoy doing stuff myself so I can learn and then help others.
