DMM-digital multimeter. You can use this to verify grounds, voltage and continuity all throughout the wiring harness. The DLC( diagnostic link connector) is where you plug in the scantool. If you get an error in communicating to the modules present in the system it would mean that there is a " Bus Communication " issue. The possibilities are either a wiring issue or a component failure such as the PCM.
