Scrambler62
I have a 2003 Wrangler Sport 4.0 5 speed
For the past year or more I have been chasing code P0135 and P0155 - 02 Sensor Heater Circuit Malfunction (Bank I Sensor 1, Bank 2 Sensor 1)
Replaced O2 sensors multiple times, checked wiring everything spot on.
The fix Wrong Thermostat. I replaced radiator and thermostat when I first got jeep but I put in 180 degree thermostat.
The factory spec is 195
Computer is programed for engine to heat to above 195 in certain set time, if it doesn't it throws code.
Engine idles better, shifts smoother, no cel over 3 weeks, now running at 207
Check thermostat for correct operation and heat range if you experience same.
Hope this is helps, Best
