jeeperscreepers
I have an 89 Jeep Comache Pickup that I got from my grandfather. It always had a problem with overheating. Before I got it from him he had the heads off and those were tested for leaks cracks ect. When we got it, it still ran hot, so we put in new fan clutch, thermostat, waterpump, and radiator. nothing happened. The weird thing is all the water is bypassing the radiator and giong into the recovery tank and the boiling out. If we clamp the two hoses the go to the tank off it seems to run fine. So we bypasses that entire part of the system and it ran ok for a couple of days, but when you take it above 70 mph the indicator light comes on. We have tried everything any help at all would be appreciated. Thanks :-? [addsig]
