Options for alittle more lift??
288sunny
I currently have a 4" lift (atleast i was told it was) and a 1" body lift. I just upgraded to 35 12.50 15's MTZ's and it appears to be a bit cramped, i dont think just normal driving they will rub, but any off road will be cutting it close, what Suspension options do i have to gain alittle more clearance, besides doing a full 6" long arm lift? Could i do coil spacers? is there anything else? also how would i go about adding some bump stops to make sure they dont hit the fender?
you should have more than enough space with a 4" lift and a 1" BL.
What model Jeep?
If it's a TJ, you should have plenty for 35" tires with the combined 5" you have now. It's possible your springs could be sagged depending on age and use, so it's possible new 4" springs could improve things.
I wouldn't add spacers to 4" springs, it becomes too much combined spring/spacer height for a short-arm suspension.
Be sure to have your bumpstops properly adjusted to prevent over-compression and premature wear on the springs.
